    M5Paper stuck in M5.begin();
    Cores
    8.8k
      michael_o
      I'm doing my first steps with the M5Paper and even the slightest examples often fail, because the device is stuck in the M5.begin() function - it never returns from it.
      With the next upload, it works again, slightest change - stuck again.
      I'm using Arduino IDE. Am I doing something wrong or is my device faulty?
      Best regards,
      Michael
        Are you resetiing the M5Paper between each programming attempt?
          michael_o
          I'm not manually resetting it, no. But even if I reset it, it doesn't work.
            Hello @michael_o
            would you mind sharing one of the examples which fails on your M5Paper?
              michael_o
              Sure. Even this tiny example fails. It prints "Begin", but not the "initializing ... OK" which M5.begin() usually prints.
              #include <M5EPD.h>
              M5EPD_Canvas canvas(&M5.EPD);
              Serial.begin(115200);
              Serial.printf("Begin\n");
              delay(1000);
              M5.EPD.Clear(true);
              yield();
                Hello @michael_o
                thanks. Most likely the issue is the double initialisation of Serial. If you have a look into M5.begin() you'll see that by default it initialises Serial as well.
                    if (SerialEnable == true)
                        Serial.flush();
                        delay(50);
                        Serial.print("M5EPD initializing...");
                So I suggest you change your code to:
                #include <M5EPD.h>
                  M5.EPD.Clear(true);
                Note: untested as my M5Paper currently is in a long term battery test.
                Hope this helps.
                  michael_o
                  That's right, it looks like that was the problem. Thank you very much. What a peculiar behaviour if you init Serial twice.
                  Michael
                    Hello @michael_o
                    you are welcome. I am glad to hear you got it working and thank you for reporting back here.
                    Cheers
