    M5core 12 channel Server Module not work.
    Modules
    3.3k
    • T
      TheAlphaGhost
      Hi Gents,
      i have a Problem with my Servo module. I buy the M5Core 12 channel Servo modul, and connect my servo on Port 0 from the Modul, but the Servo not work.
      I have a running example for the Arduino, which works well with the Servo. I think the problem is my logic to move the code from Arduino Uno to M5Core 12 Channel Servo modul.
      That is working with Arduino Uno:
      #include <SoftwareSerial.h>
      SoftwareSerial mySerial(10, 11); // RX, TX
      void setup()
        Serial.begin(9600);
        mySerial.begin(115200);
        Serial.println("start");
      void servo(char ServoId, char Mode, char Degrees, char Speed)
        // Build checksum;
        int sum = ServoId + Mode + Degrees + Speed;
        char zero = 0;
        while (sum > 255)
          sum -= 255;
        //Head (Preamble)
        mySerial.write(0xFA); // Byte 1: Preamble;
        mySerial.write(0xAF); // Byte 2: Preamble;
        //Data
        mySerial.write(ServoId); // Byte 3: ServoID (See label of servo)
        mySerial.write(Mode);    // Byte 4: Command; for “go to command” we have = 0x01; we will try to find some other commands shortly
        mySerial.write(Degrees); // Byte 5: position = 120 + desired position in degrees;
        mySerial.write(Speed); // Byte 6: duration = duration in ms / 20
        mySerial.write(zero);  // Byte 7: 0x00 (? we don’t know what this is yet)
        mySerial.write(zero);  // Byte 8: 0x01 (? we don’t know what this is yet)
        //Check & End
        mySerial.write(sum);  // checksum = sum(byte 3 through 8) mod 256
        mySerial.write(0xED); // closure = 0xED (from “END”?)
      void loop()
        servo(16, 1, 45, 40);
        delay(2000);
        servo(16, 1, 0, 10);
        delay(2000);
      And here i try move my code to M5Stack with 12 channel Servo Modul, which are not work on Port 0. Have any a idea ?
      #include <Arduino.h>
      #include <M5Stack.h>
      #include <Wire.h>
      #define SERVO_ADDR 0x53
      void setup()
          M5.begin(true, false, true);
          M5.Power.begin();
          M5.Lcd.setTextFont(4);
          M5.Lcd.setCursor(70, 100);
          M5.Lcd.print("Servo Example");
          Wire.begin(21, 22, 115200);
          Wire.beginTransmission(SERVO_ADDR);
          Wire.write(0x00);
          // Build checksum;
          char zero = 0;
          while (sum > 255)
              sum -= 255;
          //Head (Preamble)
          Wire.write(0xFA); // Byte 1: Preamble;
          Wire.write(0xAF); // Byte 2: Preamble;
          Wire.write(ServoId); // Byte 3: ServoID (See label of servo)
          Wire.write(Mode);    // Byte 4: Command; for “go to command” we have = 0x01; we will try to find some other commands shortly
          Wire.write(Degrees); // Byte 5: position = 120 + desired position in degrees;
          Wire.write(Speed); // Byte 6: duration = duration in ms / 20
          Wire.write(zero);  // Byte 7: 0x00 (? we don’t know what this is yet)
          Wire.write(zero);  // Byte 8: 0x01 (? we don’t know what this is yet)
          Wire.write(sum);  // checksum = sum(byte 3 through 8) mod 256
          Wire.write(0xED); // closure = 0xED (from “END”?)
          Wire.endTransmission();
      void loop()
          delay(2000);
          delay(2000);
      Can anyone help me, please... ?
