I want to communicate data with M5stack Core2 and COM.Sigfox.
Hello. I bought M5stack Core2 and COM.Sigfox. I want to use this for data communication.
I was able to register the module in the sigfox backend. But I can't communicate or call back.
When I use M5stack Basic and COM.Sigfox,I can do data communication and callbacks.
Is there something wrong with my sketch?#include <M5Core2.h> void setup() { M5.begin(true, false, true); Serial2.begin(9600, SERIAL_8N1, 13, 14); Serial.begin(9600); } void loop() { int val = 11223344; String msg = String(val, HEX); Serial.print( msg); Serial.println(" msg "); Serial2.print("AT$SF=" + msg); Serial.print("AT$SF=" + msg); Serial.println(" AT$SF= msg "); delay(15*1000); }
Hello @takero
in this example sending a command uses
Serial2.write("AT$SF=00FFEE\r\n");
instead ofprint()
. In another example I foundprintln()
was used.I have a feeling the COM.Sigfox module would like a
\r\n
as a line end. (But that is just a guess as I don't have that module and cannot test myself.)Good luck!
Felix -
Thank you for suggestion Felix. And Sorry for my late reply.
I triedSerial2.println("AT$SF=" + msg );
orSerial2.println("AT$SF= + msg ");
.and
Serial2.write("AT$SF= + msg ");
orSerial2.write("AT$SF=" + msg );
.But I couldn't communicate.
If you have new tips, I would love to try.Thank you.
@felmue Thank you.
I tried your sample. I succeeded in compiling.
But I can't write to core2 since yesterday.Displayed "A fatal error occurred: Failed to connect to ESP32: Timed out Waiting for packet header"
Both of the Core2 I have are like that. Did my Core 2 break?
I just wrote a sketch.Thank you.
Hello @takero
sorry to hear. It's very unlikely that both of your M5Core2 devices just broke like that. Some suggestions:
- Have you tried a different USB cable?
- Have you tried a different USB port?
- Have you tried closing and reopening your software?
- Have you tried to reboot your computer?
Felix -
Thank you @felmue .I have tried your suggestion.
Have you tried a different USB cable? :Yes I did.
Have you tried a different USB port? :Yes I did.
Have you tried closing and reopening your software? :Yes I did.
Have you tried to reboot your computer? :Yes I did.However, I got an error. Isn't my Core 2 broken ?
I tried another sketch and the result was the same.
At that time, I connected the actual sensor.
DHT22 to GPIO72.
DS18B20 to GPIO26.
Analog sensor to GPIO36.
Is that not good?
Thank you. -
Hello @takero
until you have figured out the issue regarding flashing a sketch (any sketch) onto your M5Core2, I'd do the following:
- only connect the USB cable to your computer
- disconnect everything else
- try flashing a sketch
If that doesn't work, then maybe your M5Core2 has been damaged (still very unlikely though).
While I was writing to Core 2, I pressed the power button for a long time and the writing was successful.Thank you.
