    M5Stack Fire does not start with LoRa868 modules
    M5Stack Fire
    fire
    5.3k
      sysLINK
      Hello all,
      I received my M5Stack Fire yesterday.
      In addition, I bought the LoRA868 module.
      Without module the device works without problems.
      But when I install the module, the device starts only after several presses of the power button and not always.
      With the M5Burner I have already installed the current version 1.7.1-fire without problems.
      On the board is the No. 2018.2A printed I think that this is the version.
      Can someone help me here?
        Hello @sysLINK
        I understand you've installed UIFlow 1.7.1-fire firmware on your M5Stack Fire, correct?
        I do not have the LoRA868 module myself so my conclusion could be wrong. But looking at the spec sheet of the LoRA868 module I don't see UIFlow mentioned, so I don't think this module has UIFlow integration.
        Have you tried the Arduino example?
