<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[M5Stack Fire does not start with LoRa868 modules]]></title><description><![CDATA[<p dir="auto">Hello all,</p>
<p dir="auto">I received my M5Stack Fire yesterday.<br />
In addition, I bought the LoRA868 module.</p>
<p dir="auto">Without module the device works without problems.<br />
But when I install the module, the device starts only after several presses of the power button and not always.</p>
<p dir="auto">With the M5Burner I have already installed the current version 1.7.1-fire without problems.</p>
<p dir="auto">On the board is the No. 2018.2A printed I think that this is the version.</p>
<p dir="auto">Can someone help me here?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://community.m5stack.com/topic/2740/m5stack-fire-does-not-start-with-lora868-modules</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 18:18:21 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2740.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 09 Jan 2021 09:54:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to M5Stack Fire does not start with LoRa868 modules on Thu, 14 Jan 2021 22:25:08 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/syslink" aria-label="Profile: sysLINK">@<bdi>sysLINK</bdi></a></p>
<p dir="auto">I understand you've installed UIFlow 1.7.1-fire firmware on your M5Stack Fire, correct?</p>
<p dir="auto">I do not have the LoRA868 module myself so my conclusion could be wrong. But looking at the spec sheet of the <a href="https://docs.m5stack.com/#/en/module/lora868" target="_blank" rel="noopener noreferrer nofollow ugc">LoRA868 module</a> I don't see UIFlow mentioned, so I don't think this module has UIFlow integration.</p>
<p dir="auto">Have you tried the <a href="https://github.com/m5stack/M5Stack/blob/master/examples/Modules/LORA868_SX1276/LoRa868Duplex/LoRa868Duplex.ino" target="_blank" rel="noopener noreferrer nofollow ugc">Arduino example</a>?</p>
]]></description><link>https://community.m5stack.com/post/11748</link><guid isPermaLink="true">https://community.m5stack.com/post/11748</guid><dc:creator><![CDATA[felmue]]></dc:creator><pubDate>Thu, 14 Jan 2021 22:25:08 GMT</pubDate></item></channel></rss>
