    UART communication problem
    Scheduled Pinned Locked Moved M5Stack Fire
    4 Posts 2 Posters 7.8k Views
      houkensjtu
      I'm trying to use the UART port (grove C) on the Fire to talk to my computer. My computer use a FTDI USB-RS232 converter to generate the serial signal.
      I found I can detect some signal from the fire on my computer, but Fire cannot read the signal from computer. (I used pyserial to send the signal from my computer)
      I guess it's because UART is not compatible with RS232 signal but I'm not sure. Please help if you have related experience.
      Thanks,
      • sodokuS Offline
        sodoku
        Can you try a different port (A or B)? Fire has PSRAM on the same pins as the signals on Port C and that can make issues.
          houkensjtu
          OK, I will try Grove A and B. By the way, what's the signal level of UART on Fire? I suspect it's not compatible with RS232 signal. (I see some microcontrollers need a converter to convert between TTL and RS232).
          Thank you!
          • sodokuS Offline
            sodoku
            Sorry, that I don't know.
