<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UART communication problem]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I'm trying to use the UART port (grove C) on the Fire to talk to my computer. My computer use a FTDI USB-RS232 converter to generate the serial signal.<br />
I found I can detect some signal from the fire on my computer, but Fire cannot read the signal from computer. (I used pyserial to send the signal from my computer)</p>
<p dir="auto">I guess it's because UART is not compatible with RS232 signal but I'm not sure. Please help if you have related experience.</p>
<p dir="auto">Thanks,</p>
]]></description><link>https://community.m5stack.com/topic/2673/uart-communication-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 23:16:16 GMT</lastBuildDate><atom:link href="https://community.m5stack.com/topic/2673.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Dec 2020 20:51:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UART communication problem on Thu, 31 Dec 2020 01:32:59 GMT]]></title><description><![CDATA[<p dir="auto">Sorry, that I don't know.</p>
]]></description><link>https://community.m5stack.com/post/11458</link><guid isPermaLink="true">https://community.m5stack.com/post/11458</guid><dc:creator><![CDATA[sodoku]]></dc:creator><pubDate>Thu, 31 Dec 2020 01:32:59 GMT</pubDate></item><item><title><![CDATA[Reply to UART communication problem on Thu, 31 Dec 2020 01:24:04 GMT]]></title><description><![CDATA[<p dir="auto">OK, I will try Grove A and B. By the way, what's the signal level of UART on Fire? I suspect it's not compatible with RS232 signal. (I see some microcontrollers need a converter to convert between TTL and RS232).</p>
<p dir="auto">Thank you!</p>
]]></description><link>https://community.m5stack.com/post/11457</link><guid isPermaLink="true">https://community.m5stack.com/post/11457</guid><dc:creator><![CDATA[houkensjtu]]></dc:creator><pubDate>Thu, 31 Dec 2020 01:24:04 GMT</pubDate></item><item><title><![CDATA[Reply to UART communication problem on Wed, 30 Dec 2020 22:30:43 GMT]]></title><description><![CDATA[<p dir="auto">Can you try a different port (A or B)? Fire has PSRAM on the same pins as the signals on Port C and that can make issues.</p>
]]></description><link>https://community.m5stack.com/post/11452</link><guid isPermaLink="true">https://community.m5stack.com/post/11452</guid><dc:creator><![CDATA[sodoku]]></dc:creator><pubDate>Wed, 30 Dec 2020 22:30:43 GMT</pubDate></item></channel></rss>
