    M5Paper Image conversion
    Cores
    5.5k
    • B
      Beetix
      I've forked the Factory Test and I'm trying to add new image resources. What source image format and tool (Linux compatible) should I use to generate C arrays like in ImageResource.h?
      • ZontexZ
        Zontex @Beetix
        @beetix Hi ! feel free to look over our API: epd_canvas
        if you want to use data to draw, you need to use this tool to convert image to data.
        • B
          Beetix
          Thank you for your reply. Yes, I did stumble upon the bin2code.py script you mention. The issue is that it doesn't convert the image to raw pixel data (usable by M5EPD_Driver::WriteFullGram4bpp).
          After a bit more research, I found a preliminary command using ImageMagik to convert an image to raw pixel data for the M5EPD: convert input.png -depth 4 -negate output.gray
          Then convert the raw data to C with bin2code.py : ./bin2code.py output.gray
          The result can then be appended to ImageResource.h
