    How to change the I2C adress of a module ?
    Modules
    6.9k
    • R
      ramaker
      I want to use 2 COPLUS motor driver moduls for 4 DC motors.
      I read in the forum that I have to change to I2C adress via a modification of the firmeware. (change the default adress and burn a new firmware.)
      How can I do that ? is there a special software ?
      Is there a list of used I2C adresses inside the M5Stack system - so I canfind a "free" I2C adress ?
      OR .... is there an easy way to controll 4 DC motors ?
      K.D.
      • sodokuS
        sodoku
        The documentation page has a list of i2c addresses:
        https://static-cdn.m5stack.com/image/m5-docs_table/I2C_Address.pdf
        • R
          ramaker
          Thank you - thats helpfull !!
          Just a little question - maybe a Dummy question:
          How do you know that ?
          How do you know that there is an adress like you send me ?
          Is there any documentatio I have to go thru - to know all that things ??
          Next thing concerning I2C change:
          I read, that I should use a software called "M5burner"., It is the same that I find in every documentation in the beginning.
          There you should have the possibility to download firmware and flash it.
          I tried the software, but I can not find any possibility for download a firmware or a piece of software.
          Is there a documentation for "M5burner" ?
          regards
          K.D.
          • sodokuS
            sodoku
            I am just very excited about M5Stack stuff at the moment and I am poking around everywhere. :)
            I found that table at docs.m5stack.com in the top navigation:
            • sodokuS
              sodoku
              There is are quick start guides that also explain how to use M5Burner. Here is one https://docs.m5stack.com/#/en/quick_start/m5core/m5stack_core_get_started_MicroPython?id=m5burner
              • R
                ramaker
                Oh - I made a mistake !
                It is not the software "M5burner" - this is clear for me - excuse me.
                I do not understand "EasyLoader".
                This software is mentioned on the top of every documentation and there are different versions for every unit.
                But what is the software flashing ? -
                I know that EasyLoader flashing "a firmware" - but were is it from and what firmware ?
                Is it a kind of update service ?
                In one topic of this forum it is said, that I can cange the I2C adress with this software. I have only change a line value inside a file or script ??? no more info.
                Do you know more about that software and how it is working ?
                Thank you again for your helpful answers.
                regards
                K.D.
                p.s. I'm exited too about M5Stack and I want to use it in a autonomous vehicle. That's why I'm asking for the use of multiple sensors and motors.
