    Libraries/Frameworks/Software for GUI design for M5Core2
    SOFTWARE
    5
    7
    17.6k
    • innovationsmakerI
      innovationsmaker
      Hello guys,
      This is my first post here and I am just getting acquainted with the M5Core2. So I am looking for all the options of designing a good looking UI for controlling Home Assistant. Does any of you know any good tool similar to UI Flow but with more options for customisation?
      So far I have found the following options:
      1. The UI flow(of course) but I don't like its limitations. I cannot make a scrolling view or create multiple views.
      2. LVGL - https://lvgl.io/ Looks very promising and I see there are some expanses for Core2
      3. Using plain MicroPython(with no special GUI frameworks)
      4. Using Arduino IDE
      Also, I quite liked the factory firmware that the Core2 came with. The interface was very fast and responsive and the graphics look very pleasant. Do you know what technologies were used in this factory firmware?
      Nothing will work, unless you do!
      • ZontexZ
        Zontex
        Hi, for the factory firmware we used LVGL, you can check it out here: https://lvgl.io/
        you've already mentioned it in your second point and it's the same one we use so I would highly recommend you to try to go with this one and see how it goes.
        innovationsmakerI 1 Reply Last reply Reply Quote 0
        • innovationsmakerI
          innovationsmaker @Zontex
          @zontex Thank you for your answer. While on this topic: Is it possible to make UI with different tabs/pages/views using UI Flow or I have to go with LVGL?
          • world101W
            world101 @innovationsmaker
            @innovationsmaker said in Libraries/Frameworks/Software for GUI design for M5Core2:
            Yes you can look at this flow from my github
            https://github.com/bstein2379/M5StickC-Plus-Ringtone-Jukebox
            It’s not for the Core2, but you’ll get the idea of how to create a menu structure with different views using uiFlow.
            • innovationsmakerI
              innovationsmaker @world101
              @world101 I looked at your project and I think it would be a very good starting point for my idea. Thank you!
              • T
                theMusicMan
                Apologies for resurrecting an old thread, but have you seen SquareLine Studio? If you’re still designing UI’s for your m5core2 you might like to take a look.
                  macsbug
