    M5.Axp.ScreenBreath() crashes when used in interrupt
    M5 Stick/StickC
    4.3k
      M95D
      Hi.
      It seems that M5.Axp.ScreenBreath() crashes when it is used in a interrupt. Try the demo below in Arduino IDE. It should turn off the display after a timer delay and turn it back on when the button is pressed.
      On my system this program crashes with a watchdog timeout during i2c operation.
      #include <M5StickC.h>  //define M5StickC hardware components and functions
      #define BUTTON_MAIN 37  //The main button pin number
      #define SCREEN_TIMEOUT 10 //Screen-off timeout in seconds
      hw_timer_t *timer;
      void IRAM_ATTR onButton() { //Interrupt on button press => turn on the screen
       detachInterrupt(BUTTON_MAIN); //Ignore more button presses
       M5.Axp.ScreenBreath(10); //Set screen light ON
       timerAlarmEnable(timer); //Start timer for screen-off delay
      void IRAM_ATTR onTimer(){  //Interrupt on timer => turn off the screen
       timerAlarmDisable(timer); //Stop the timer.
       M5.Axp.ScreenBreath(0); //Set screen light OFF
       attachInterrupt(BUTTON_MAIN,onButton,FALLING); //Attach interrupt on button press => turn on the screen
      M5.begin(); //Init M5
      M5.Lcd.fillScreen(YELLOW); //Make screen yellow
      pinMode(BUTTON_MAIN, INPUT_PULLUP); //Button GPIO set as input, pull-up enabled
      timer=timerBegin(1,40000,true); //Init screen light timer, divisor 40000 => 0.5ms steps
      timerAttachInterrupt(timer,&onTimer,true);  //Set screen light timer interrupt function
      timerAlarmWrite(timer,SCREEN_TIMEOUT*2000,true); //Set interrupt to turn off screen after X timer steps of 0.5ms each.
        //No code here.
        Hello @M95D
        interrupt functions need to be as short as possible, run from RAM and everything in it (e.g. every function you call from within) also needs to run from RAM. In your case only onTimer() is in RAM, but everything else is probably not. All this is causing the watchdog to trigger.
        To solve the issue, you should only set a flag in the interrupt function and test this flag in the loop() function and then act upon it.
        Try something like this:
        hw_timer_t *timer;
        volatile bool onButtonFlag = false;
        volatile bool onTimerFlag = false;
          onButtonFlag = true;
          onTimerFlag = true;
          if(onButtonFlag) {
          if(onTimerFlag) {
        Cheers
          M95D
          Works. Thank you!
