    M5StickC Plus MicroPython: Use GPIO 25 and 26 for I2C, 36 Floating
    M5 Stick/StickC
    10.6k
    • J
      JackH
      Hi, I would like to use the GPIO 25 and 26 pins in the header for I2C, so I am setting them up as follows in MicroPython:
      from machine import Pin, I2C
      i2c = I2C(1, scl=Pin(26), sda=Pin(25), freq=400000)
      However, the description says that "G36/G25 share the same port, when one of the pins is used, the other pin should be set as a floating input" and provides the following example
      For example, to use the G36 pin as the ADC input, Configuration the G25 pin as FLOATING
      setup()
      pinMode(36, INPUT);
      gpio_pulldown_dis(GPIO_NUM_25);
      gpio_pullup_dis(GPIO_NUM_25);
      It seems that I should set GPIO36 to Floating. How does one do this in MicroPython, and where could one find such settings in the documentation? I have looked for a couple of hours and can't find this anywhere.
      Jack
      PS How do you create a code window on this board?
        Hello Jack
        you could try the following to make GPIO36 floating:
        p36 = Pin(36, Pin.IN, None)
        Please note: I do not own a M5StickC Plus so I've tried above code on a M5Stack Fire. It runs without error.
        That said, I don't think GPIO36 has internal pull-up or pull-down circuitry to begin with since the following code did not change the voltage reading at all:
        p36 = Pin(36, Pin.IN, Pin.PULL_UP)
        BTW: When I define a pull-up for let's say GPIO25 the voltage goes up to about 3.2 volts as I would expect.
        For reference: https://docs.micropython.org/en/latest/library/machine.Pin.html
        Cheers
        • J
          JackH
          Excellent, thank you very much Felix. And nice informative site you have there!
          May I ask how you ensure that MPU6886 is off in MicroPython?
            Hello Jack
            you are welcome and thank you.
            You'll need to check the MPU6886 datasheet
            There is a sleep mode bit (Bit 6) in register 107 (power management 1). When I read that register I get 0x01 which seems to be the default. To put MPU6886 into sleep mode I'd write 0x41 into that register like that:
            import i2c_bus
            i2c0 = i2c_bus.easyI2C(i2c_bus.PORTA, 0x68, freq=400000)
            i2c0.write_u8(107, 0x41)
