    M5.Axp.ScreenBreath() crashes when used in interrupt
    1 Posts 1 Posters 3.1k Views
      M95D
      Hi.
      It seems that M5.Axp.ScreenBreath() crashes when it is used in a interrupt. Try the demo below in Arduino IDE. It should turn off the display after a timer delay and turn it back on when the button is pressed.
      On my system this program crashes with a watchdog timeout during i2c operation.
      #include <M5StickC.h>  //define M5StickC hardware components and functions
      #define BUTTON_MAIN 37  //The main button pin number
      #define SCREEN_TIMEOUT 10 //Screen-off timeout in seconds
      hw_timer_t *timer;
      void IRAM_ATTR onButton() { //Interrupt on button press => turn on the screen
       detachInterrupt(BUTTON_MAIN); //Ignore more button presses
       M5.Axp.ScreenBreath(10); //Set screen light ON
       timerAlarmEnable(timer); //Start timer for screen-off delay
      void IRAM_ATTR onTimer(){  //Interrupt on timer => turn off the screen
       timerAlarmDisable(timer); //Stop the timer.
       M5.Axp.ScreenBreath(0); //Set screen light OFF
       attachInterrupt(BUTTON_MAIN,onButton,FALLING); //Attach interrupt on button press => turn on the screen
      M5.begin(); //Init M5
      M5.Lcd.fillScreen(YELLOW); //Make screen yellow
      pinMode(BUTTON_MAIN, INPUT_PULLUP); //Button GPIO set as input, pull-up enabled
      timer=timerBegin(1,40000,true); //Init screen light timer, divisor 40000 => 0.5ms steps
      timerAttachInterrupt(timer,&onTimer,true);  //Set screen light timer interrupt function
      timerAlarmWrite(timer,SCREEN_TIMEOUT*2000,true); //Set interrupt to turn off screen after X timer steps of 0.5ms each.
        //No code here.
