This code works on the SD card for me, Remember to format Fat32 and keep device size 32GB or less
import machine import os import time # --- Configuration for M5Stack CoreS3 SD Card --- SD_SCK = 36 SD_MISO = 35 SD_MOSI = 37 SD_CS = 4 # Configuration for machine.SDCard SD_SLOT = 2 # Typically used for SPI access on ESP32/S3 SD_FREQ = 1000000 # 1MHz frequency for reliable initialization MOUNT_POINT = "/sd" TEST_FILE_PATH = MOUNT_POINT + "/cores3_test_log.txt" def initialize_and_mount_sd(): """Initializes the SD card interface and mounts the filesystem.""" print("Attempting to initialize SD card...") try: # Initialize the SDCard object using the specific pins for the CoreS3 sd = machine.SDCard( slot=SD_SLOT, sck=machine.Pin(SD_SCK), miso=machine.Pin(SD_MISO), mosi=machine.Pin(SD_MOSI), cs=machine.Pin(SD_CS), freq=SD_FREQ ) print("Hardware initialized.") # Mount the SD card filesystem (VfsFat) vfs = os.VfsFat(sd) os.mount(vfs, MOUNT_POINT) print(f"SD Card successfully mounted at {MOUNT_POINT}") return vfs except Exception as e: print(f"ERROR initializing or mounting SD card: {e}") print("Please ensure the SD card is inserted correctly and formatted (FAT32).") return None def write_demo(filepath): """Writes sample data to a file on the SD card.""" print(f"\n--- Writing Demo ---") content = "Hello from M5Stack CoreS3!\n" content += f"MicroPython SD Card Test.\nTimestamp: {time.time()}" try: # Open the file in write mode ('w') with open(filepath, "w") as f: bytes_written = f.write(content) print(f"Successfully wrote {bytes_written} bytes to {filepath}") return True except Exception as e: print(f"ERROR writing to file: {e}") return False def read_demo(filepath): """Reads data from the file on the SD card.""" print(f"\n--- Reading Demo ---") try: # Open the file in read mode ('r') with open(filepath, "r") as f: data = f.read() print(f"Contents of {filepath}:") print("-" * 30) print(data) print("-" * 30) except Exception as e: print(f"ERROR reading from file: {e}") def list_directory_demo(path): """Lists the contents of the directory with file sizes.""" print(f"\n--- Directory Listing Demo ({path}) ---") try: items = os.listdir(path) if not items: print("(Empty Directory)") return print(f"{'Name':<25} {'Size (Bytes)':>15}") print("-" * 41) for item in items: try: # os.stat returns a tuple; index 6 contains the file size stats = os.stat(path + "/" + item) size = stats[6] print(f"{item:<25} {size:>15}") except Exception as e: print(f"{item:<25} (Error getting stats)") except Exception as e: print(f"ERROR listing directory: {e}") def unmount_sd(mount_point): """Unmounts the SD card filesystem.""" print("\n--- Unmounting ---") try: # Crucial to prevent corruption os.umount(mount_point) print("SD Card unmounted successfully.") except Exception as e: print(f"ERROR unmounting SD Card: {e}") def main(): print("Starting M5Stack CoreS3 SD Card Demo") # 1. Initialize and Mount vfs = initialize_and_mount_sd() if vfs: # 2. List initial contents list_directory_demo(MOUNT_POINT) # 3. Write data if write_demo(TEST_FILE_PATH): # 4. Read data back read_demo(TEST_FILE_PATH) # 5. List contents again to show the new file and size list_directory_demo(MOUNT_POINT) # 6. Unmount unmount_sd(MOUNT_POINT) else: print("Demo aborted due to SD card initialization failure.") if __name__ == "__main__": main()
