User
Hi,
With microPython on esp32 C3 mate, I would like to use a 3A Relay unit, for that I use GP19 which are also dedicate for USA D+, with the following code:
'''python3
import machine
relay = machine.Pin("GP19", machine.Pin.OUT)
if temp > 42:
relay.value(1)
elif temp < 40:
relay.value(0)
else:
pass
But I have this error:
File "main.py", line 7, in <module>
ValueError: invalid pin
Do you know why?
Is it possible to use GP19 for a relay even if this Pin is dedicate to USA D+?
Thanks you,
Sebastien
