Zontex,
Thank you so much for your help and for the explanation!
Best regards,
Raquel
Posts made by RB 0
RE: Problems controlling stepper motor while microsteppingposted in SOFTWARE
Hi Zontex, I did what you suggested and now it works fine. Thank you very much.
However, I do not understand why. Because in order to activate the 1/32 microstepping mode, M0, M1 and M2 must be in the high state. Since it is so hard to solder the pins because they are located in a difficult area of the board, I figured I could just sold everything together and they all should be in a high state this way.Anyway, thank you very much for your help, it worked.
Hello !
The code and soldering are here: https://imgpile.com/i/u0zYLP
I activated the 1/32 microstepping mode by soldering the 3 jumpers in the board....
Does anyone else have problems controlling a stepper motor using UIFLOW software while microstepping?
It was working perfectly for full step mode. Now I've changed to microstepping at 1/32 and I cannot move the stepper up or down or whatever !!
RE: Advanced pins programig help!posted in Lessons and Guides
Hi mb ! Thank you for your repply ! I followed your sugestion and uploaded the picture. Here it goes:
https://imgpile.com/images/uL9Vg4.png
Unfortunatly you can't preview it of course.
Thanks a lot for your help. -
I mean... I can't upload the image... i connected the switch to 3.3V and GPIO36, used a resistor to connect to ground... and in the programing I used the [Init pin0 (Pin 36) mode IN PULL_UP] and used an [if GET pin0 value = 0] [Set Screen backgroundColor].
Hi ! Can anyone tell me how can I connect a button on m5stack PINs? I did the connections on the image but it gave some strange results: the device would have trouble connecting via USB, or it turnd ON but doing nothing or simple turning OFF instead.. This is an endstop button that is connected on a normally ON state
RE: How to navigate between screen using buttonsposted in Lessons and Guides
That was really helpful thank you a lot!
I'm now learning to program the M5stack. I came to a limitation, either mine or UIflow's ! I want to use the buttons to navigate between different screens (select an option and moving to another screen, with another options) but then I cannot visualize the layout properly because everything becomes overlapped! I'm using the commands to show/hide the labels in the different screens but overall, it's a really big mess! Can someone help?
