Hi, I am trying to get a project running on a Core2, I am getting errors related to the GPIO config.
I am using PIO in VSC, my PIO environment is setup as follows.
release (board: m5stack-core2; platform: espressif32; framework: arduino)
These are the GPIO config errors I am getting
Initialising Hardware
E (467) gpio: GPIO can only be used as input mode
[   495][E][esp32-hal-gpio.c:130] __pinMode(): GPIO config failed
E (484) gpio: GPIO can only be used as input mode
[   511][E][esp32-hal-gpio.c:130] __pinMode(): GPIO config failed
E (494) gpio: GPIO can only be used as input mode
[   522][E][esp32-hal-gpio.c:130] __pinMode(): GPIO config failed
E (504) gpio: GPIO can only be used as input mode
[   532][E][esp32-hal-gpio.c:130] __pinMode(): GPIO config failed
E (514) gpio: GPIO can only be used as input mode
[   542][E][esp32-hal-gpio.c:130] __pinMode(): GPIO config failed
E (525) gpio: GPIO can only be used as input mode
[   553][E][esp32-hal-gpio.c:130] __pinMode(): GPIO config failed
E (535) gpio: GPIO can only be used as input mode
[   563][E][esp32-hal-gpio.c:130] __pinMode(): GPIO config failed
E (545) gpio: GPIO can only be used as input mode
[   573][E][esp32-hal-gpio.c:130] __pinMode(): GPIO config failed
E (556) gpio: GPIO can only be used as input mode
[   583][E][esp32-hal-gpio.c:130] __pinMode(): GPIO config failed
This is my pins.h configuration
I have used 100 for pins that are not currently used/required in the project.
 * M5STACK CORE2
 * UNTESTED
 * NOTE M5STACK CORE2 has SD card on GPIOs 4/23/38/18
#ifdef M5_STACK_CORE2
    #define BOARD_TYPE              "m5stack-core2"
    // Define Physical Pins
    // VAC CONTROL
    #define VAC_SPEED_PIN               100                      // Built in DAC1 - used for speed reference for VFD (0-3v)
    #define VAC_BLEED_VALVE_PIN         100                      // Built in DAC2 - used for bleed valve control
    #define VAC_BANK_1_PIN              100                      // vac motor(s) on/off
    #define VAC_BANK_2_PIN              100                      // Provision for 2 stage Vac motor control
    #define VAC_BANK_3_PIN              100                      // Provision for 3 stage Vac motor control
    // SENSORS
    #define SPEED_SENSOR_PIN            100                      // turbine / rotor speed for turbo / blower flow bench
     // SWIRL ENCODER
    #define SWIRL_ENCODER_PIN_A         100
    #define SWIRL_ENCODER_PIN_B         100
   // ORIFICE DETECTION
    #define ORIFICE_BCD_BIT1_PIN        100
    #define ORIFICE_BCD_BIT2_PIN        100
    #define ORIFICE_BCD_BIT3_PIN        100
    //STEPPER MOTOR CONTROLLER
    #define FLOW_VALVE_STEP_PIN         100
    #define FLOW_VALVE_DIR_PIN          100
    #define AVO_STEP_PIN                100
    #define AVO_DIR_PIN                 100
    #define VCC_3V3_PIN                 100                     // Unused
    #define VCC_5V_PIN                  2                      // 10k-10k divider across 5v supply
    // NOTE: these inputs are handled by ADC
    #define MAF_PIN                     100                     // NOTE: I2C ADC is used instead
    #define REF_PRESSURE_PIN            100                     // NOTE: I2C ADC is used instead
    #define DIFF_PRESSURE_PIN           100                     // NOTE: I2C ADC is used instead
    #define PITOT_PIN                   100                     // NOTE: I2C ADC is used instead
    // NOTE: These inputs are handled by BME280
    #define TEMPERATURE_PIN             100                     // NOTE: I2C BME280 used
    #define REF_BARO_PIN                100                     // NOTE: I2C BME280 used
    #define HUMIDITY_PIN                100                     // NOTE: I2C BME280 used
    // COMMS
    #define SERIAL0_TX_PIN              1                      // API
    #define SERIAL0_RX_PIN              3                      // API
    #define SERIAL2_TX_PIN              100                     // GAUGE PROTOCOL CLOCK
    #define SERIAL2_RX_PIN              100                     // GAUGE PROTOCOL DATA
    #define SDA_PIN                     32                     // BME280 etc
    #define SCL_PIN                     33                     // BME280 etc
    //#define SD_CS_PIN                   4
    //#define SD_MOSI_PIN                 23
    //#define SD_MISO_PIN                 38
    //#define SD_SCK_PIN                  18
#endif
I hope someone here can help me resolve my problem.
Thanks.
