Hi everyone. In a M5 Stick C Plus, does pins 32 and 33 ´have any internal resistor that can be use with function INPUT_PULLUP in Arduino IDE? Thanks
P
Posts made by Peter Sain
M5 Stick Plus INPUT_PULLUP
M5 Stick C Plus temperature sensor without hat.
Hi everyone. In a M5 Stick C Plus are pins 32 or 33 analog Pins? I want to connect a DS18B20 temperature sensor to the Grove Port but i'm not getting data. I don't want do use a ADS hat because will not be functional to the solution i want. Thanks in advance
