Felmue, you genius you,
THANK YOU! Newbie high-five.
Hello,
My AtomS3 appears unresponsive after attempting to upload my first project. Now, every attempt to connect results in "A fatal error occurred: Failed to connect to Espressif device: No serial data received." The device shows a blank screen and doesn't respond.
Is there a way to perform a hardware-based factory reset using the buttons on the device?
Thank you for your help.
