I have the same issue and I'm using the Internet version. In @liushasha example, you now have 5 labels in your project. If you select the labels to edit them, like I want to rename "label5" to "welcomeMessageLabel", I can't. If you click on it to change the properties it will show the settings for the first label added. The only time you can edit them is when you first drop them in, after that you can't anymore.
RE: [NEW] UiFlow-Desktop V1.2.3 , not possible to graphically select individual text LABELS to edit them
MQTT over SSL
Do the MQTT blocks in UiFlow support connections over SSL/TLS? I can connect with multiple other things using the same settings, but I can't get the M5Stack to connect no matter what I do. The weird thing to me is that even with the big 30 second delay at the top I instantly get "connect fail" across the screen after I connect to wifi and the app starts. I've tried ssl://mqtt.blahblah.com, mqtt.blahblah.com, tcp://mqtt.blahblah.com, https://mqtt.blahblah.com and more. Any ideas?
The server is using a Let's Encrypt certificate so it doesn't need any other certificates loaded and like it I said, it works in multiple android apps, MQTT.fx, Node-RED, everywhere but here.
I even have the MQTT subscription deleted right now just to see if I could get things started. I'm currently using v1.3.1 beta only because I couldn't get it to work in the current release version and gave it a shot.
I have kids that will put the dog out and forget to let her in before they leave. Trying to put an end to that!
