Hello @felmue
I'll have a look, in fact I was looking for a block program so that it can be changed without programming knowledge.
Thanks for your help .
H
		Posts made by Harvey_13
    RE: ENV III & CORE 2posted in UIFlow
I tried to use the ENV III with my CORE 2 : I plug it and defined it on Port A.
But no way no make it works.
I tried to use the Example , changing to Core 2 and removing Bargraph reference, but without success...
Does anyone have a valid program using ENV III with Core 2?
Thanks -
    ENV IIIposted in UIFlow
Hello
On UI Flow - Web I see the ENV III module
Not on UI Flow - Desktop
I updated Desktop to version 1.0.17
Is it normal ?
