Ok so if I try with my code
#include <M5StickCPlus2.h>
#include <BleKeyboard.h>
BleKeyboard bleKeyboard("M5StickC_Keyboard", "M5Stack", 100);
bleKeyboard.begin();
Serial.println("En attente de connexion Bluetooth...");
if (bleKeyboard.isConnected()) {
// Si on appuie sur le bouton A du M5StickC
if (M5.BtnA.wasPressed()) {
Serial.println("Touche R envoyée !");
bleKeyboard.press('r');
delay(100);
bleKeyboard.releaseAll();
delay(10);
I have this error message
c:\Users\Cl�ment\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp: In member function 'void BleKeyboard::begin()':
c:\Users\Cl�ment\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:106:19: error: cannot convert 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'String'
106 | BLEDevice::init(deviceName);
| std::string {aka std::__cxx11::basic_string<char>}
In file included from C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLEServer.h:26,
from C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLEService.h:25,
from C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLEHIDDevice.h:21,
from c:\Users\Cl�ment\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.h:24,
from c:\Users\Cl�ment\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:1:
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLEDevice.h:184:27: note: initializing argument 1 of 'static void BLEDevice::init(String)'
184 | static void init(String deviceName);
c:\Users\Cl�ment\Documents\Arduino\libraries\ESP32_BLE_Keyboard\BleKeyboard.cpp:117:32: error: no matching function for call to 'BLECharacteristic::setValue(std::string&)'
117 | hid->manufacturer()->setValue(deviceManufacturer);
In file included from C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLEHIDDevice.h:20:
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:193:8: note: candidate: 'void BLECharacteristic::setValue(const uint8_t*, size_t)'
193 | void setValue(const uint8_t *data, size_t size);
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:193:8: note: candidate expects 2 arguments, 1 provided
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:194:8: note: candidate: 'void BLECharacteristic::setValue(const String&)'
194 | void setValue(const String &value);
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:194:31: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'const String&'
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:195:8: note: candidate: 'void BLECharacteristic::setValue(uint16_t)'
195 | void setValue(uint16_t data16);
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:195:26: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint16_t' {aka 'short unsigned int'}
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:196:8: note: candidate: 'void BLECharacteristic::setValue(uint32_t)'
196 | void setValue(uint32_t data32);
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:196:26: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'uint32_t' {aka 'long unsigned int'}
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:197:8: note: candidate: 'void BLECharacteristic::setValue(int)'
197 | void setValue(int data32);
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:197:21: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'int'
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:198:8: note: candidate: 'void BLECharacteristic::setValue(float)'
198 | void setValue(float data32);
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:198:23: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'float'
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:199:8: note: candidate: 'void BLECharacteristic::setValue(double)'
199 | void setValue(double data64);
C:\Users\Cl�ment\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.2\libraries\BLE\src/BLECharacteristic.h:199:24: note: no known conversion for argument 1 from 'std::string' {aka 'std::__cxx11::basic_string<char>'} to 'double'
grpc: error while marshaling: string field contains invalid UTF-8
Compilation error: grpc: error while marshaling: string field contains invalid UTF-8
My libraries
