Hi,
I try to follow the instruction
link text
but the Burner page is black. I cannot do anything. Someone can help me? Thank you!
using default /home/dell/Scaricati/M5Burner-v3-beta-linux-x64/bin/resources/app.asar/node_modules/usb-detection/build/Release/detection.node
using default /home/dell/Scaricati/M5Burner-v3-beta-linux-x64/bin/resources/app.asar/node_modules/@serialport/bindings/build/Release/bindings.node
[ENV] Use python3
[INIT] App initialized.
[10678:1229/140601.003000:ERROR:sandbox_linux.cc(376)] InitializeSandbox() called with multiple threads in process gpu-process.
(node:10646) UnhandledPromiseRejectionWarning: Error: ENOENT: no such file or directory, open '/home/dell/Scaricati/M5Burner-v3-beta-linux-x64/packages/dat/local.json'
(Use `m5burner --trace-warnings ...` to show where the warning was created)
(node:10646) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)```
