    Issues with ESP now (Cardputer-Adv, UIFlow2.3.9)
    General
    • F
      flowdev007
      Hi everyone!
      having some problems with ESP now on the latest micro python UIFlow (2.3.9).
      the simplest program I have is below, stripped right to the basics (just a loopback)
      problem is the sends go through ok i.e. no exceptions but the receiver is not picking anything up.
      I have tried a lot of things but no luck, any ideas would be greatly appreciated!
      if anyone is running obvs change Mac address.
      Thanks!!!
      import network
      from m5espnow import *  # Correct import for UIFlow firmware
      from m5espnow import M5ESPNow
      import time
      # Callback: Fires automatically on incoming messages
      def espnow_recv_callback(espnow_obj):
          sender_mac, data = espnow_obj.recv_data()  # sender_mac is hex str, data is bytes
          if data is not None:
              try:
                  msg_text = data.decode('utf-8')
              except:
                  msg_text = repr(data)
              print(f"[RECEIVED from {sender_mac}] {msg_text}")
      # 1. WiFi setup (must be in this order for stability)
      wlan = network.WLAN(network.STA_IF)
      wlan.active(True)
      wlan.config(pm=0)  # Disable power saving
      wlan.disconnect()  # Force disconnect to free radio
      wlan.config(channel=11)  # Fixed channel (try 6 or 11 if interference)
      time.sleep(0.5)  # Settle time
      # 2. M5ESPNOW setup
      e = M5ESPNow(11)  # Create instance (default wifi_ch=0)
      e.set_irq_callback(espnow_recv_callback)  # Register callback
      e.active(True)  # Activate ESP-NOW
      # 3. Get own MAC as hex string (no colons, lowercase)
      my_mac_bytes = wlan.config('mac')
      my_mac_hex = ''.join(f'{b:02x}' for b in my_mac_bytes)
      print("My MAC:", my_mac_hex)
      # 4. Add self as peer (peer_mac: str, peer_id: 1, ifidx: 0, encrypt: False)
      e.set_add_peer(my_mac_hex, 1, 0, False)
      print("=== Starting loopback test (watch for RECEIVED lines) ===")
      # 5. Send loop to self (peer_id=1)
      counter = 0
      while counter < 5:
          counter += 1
          msg = f"Hello from Cardputer! #{counter}".encode('utf-8')  # Bytes payload
          success = e.send_data(1, msg)  # Send to peer_id=1 (self)
          print(f"Sent #{counter} (success: {success})")
          time.sleep(2)  # Wait for callback to fire
