Use CORE S3 SE with battery,
Base AAA stacked on CORE S3 SE.
void setup() { auto cfg = M5.config(); cfg.output_power = false; M5.Power.begin(); M5.begin(cfg);'
This code boot from the battery.
But, this code does not output +5V to the port.cfg.output_power = true;
In this setting, CORE S3 turns on for a moment and then turns off.
I changed the settings within loop.
M5.Power.setExtOutput(true);
+5V is output, but CORE S3 turns on for a moment and then turns off.
If USB is connected, it works fine.I am having trouble using the sensor connected to the glove port.
Can anyone give me some advice?
