Private UIFLow Server code test (CM4 Stack)
 Some of you may be aware that there is a download for a private UIFlow Server available for the CM4Stack.
 I am currently looking at it at the moment and have found that there is an error with an ELF32 file when trying to run.
 I have localised it down to Raspbian running in 64bit mode whereas the Server expects a 32 bit version.Please keep visiting this post and I will update you when I get things working.
