    MQTT
    UIFlow
    5
    26
    105.7k
    • G
      gadjet @ajb2k3
      @ajb2k3 said in MQTT:
      @gadjet
      Ok something is missing that set the topic to on or off.
      Do you mean in the image I posted? that's just a flow to switch a neopixel LED on/off, no MQTT intervention.
      • ajb2k3A
        ajb2k3 @gadjet
        @gadjet
        Hmn, I need to play then.
        • D
          dvd78 @jpilarski
          @jpilarski said in MQTT:
          You have to save the file to your board. Don't use run. Once it reboots it will connect to wifi and then run the mqtt blocks.
          Hi @jpilarski, how can i save the file? don't i only need to do "download" from "http://flow.m5stack.com"?
          i have a project working great if i download it from http://flow.m5stack.com, but when i reboot the M5Stack my module won't start...
          Best
          Davide
          • ajb2k3A
            ajb2k3 @dvd78
            @dvd78 said in MQTT:
            Best
            Davide
            You need to connect you M5 to UIFlow, click the download button (a rough WIP guide is in my WIP Handbook on pages 7, 8, and 9)
            You need to click the 3 horizantal lines to get the settings up and then click download.
            When the M5 Stack restarts you need to hit the middle button (B) to get the app list then use the right button (C) to move down and then B to run the program.
            • D
              dvd78
              thank you @ajb2k3... is there a way to start the m5 immediately with your program?
              • ajb2k3A
                ajb2k3 @dvd78
                @dvd78 I think.....
                If you just power it on it should autoload the program.
