esp8266 to m5stack wifi communication
Hi, Im looking for a way to port my "espnow esp8266 to esp8266" project to m5stack
I'm using arduino core
I need to send a sensor value from esp8266 to m5stuck as faster as possiblethis is my sender code: (sorry I can't find how to insert code)
// EspnowController.ino
// a minimal program derived from
// https://github.com/HarringayMakerSpace/ESP-Now// This is the program that sends the data. (The Controller)
#include <ESP8266WiFi.h>
extern "C" {
#include <espnow.h>
}// this is the MAC Address of the slave which receives the data
uint8_t remoteMac[] = {0x36, 0x33, 0x33, 0x33, 0x33, 0x33}; //se cambia il MAC ADDRESS ricordarsi di cambiare anche il serial print per poter clonare il modulo#define WIFI_CHANNEL 4 // se cambia il canale ricordarsi di cambiare anche il serial print per poter clonare il modulo
// must match the slave struct
struct attribute((packed)) DataStruct {
char text[32];
unsigned long time;
};DataStruct myData;
unsigned long lastSentMillis;
unsigned long sendIntervalMillis = 10;
unsigned long sentMicros;
unsigned long ackMicros;unsigned long lastBlinkMillis;
unsigned long fastBlinkMillis = 200;
unsigned long slowBlinkMillis = 700;
unsigned long blinkIntervalMillis = slowBlinkMillis;byte ledPin = 14;
#include <NewPingESP8266.h>
#define TRIGGER_PIN D5 // 14 Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN D6 // 12 Arduino pin tied to echo pin on the ultrasonic sensor.
//#define MAX_DISTANCE 350 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.//NewPingESP8266 sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPingESP8266 setup of pins and maximum distance.
NewPingESP8266 sonar(TRIGGER_PIN, ECHO_PIN); // NewPingESP8266 setup of pins and maximum distance.
long echoTime;
Serial.begin(115200); Serial.println();
Serial.println("Starting EspnowController.ino");WiFi.mode(WIFI_STA); // Station mode for esp-now controller
WiFi.disconnect();Serial.printf("This mac: %s, ", WiFi.macAddress().c_str());
Serial.printf("slave mac: %02x%02x%02x%02x%02x%02x", remoteMac[0], remoteMac[1], remoteMac[2], remoteMac[3], remoteMac[4], remoteMac[5]);Serial.printf(", channel: %i\n", WIFI_CHANNEL);
if (esp_now_init() != 0) {
Serial.println("*** ESP_Now init failed");
while (true) {};
esp_now_set_self_role(ESP_NOW_ROLE_CONTROLLER);
esp_now_add_peer(remoteMac, ESP_NOW_ROLE_SLAVE, WIFI_CHANNEL, NULL, 0);esp_now_register_send_cb(sendCallBackFunction);
strcpy(myData.text, "WIFI CH 4");
//strcpy(myData.text, "CRISTO !!!");
Serial.print("WIFI_CHANNEL "); Serial.println(myData.text);pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH);
delay(500);
digitalWrite(ledPin, LOW);Serial.println("Setup finished");
echoTime = (sonar.ping_median(10));
sendData();
blinkLed();
void sendData() {
if (millis() - lastSentMillis >= sendIntervalMillis) {
lastSentMillis += sendIntervalMillis;
//myData.time = millis();
myData.time = echoTime;
uint8_t bs[sizeof(myData)];
memcpy(bs, &myData, sizeof(myData));
sentMicros = micros();
esp_now_send(NULL, bs, sizeof(myData)); // NULL means send to all peers
Serial.println("sent data");
void sendCallBackFunction(uint8_t* mac, uint8_t sendStatus) {
ackMicros = micros();
Serial.print("Trip micros "); Serial.println(ackMicros - sentMicros);
Serial.printf("Send status = %i", sendStatus);
Serial.println();
Serial.println();Serial.println("MAC ADD 0x36, 0x33, 0x33, 0x33, 0x33, 0x33"); //RICORDARSI DI CAMBIARLO SE CAMBIA NEL SETUP
Serial.println("WIFI CHANNEL 4"); //RICORDARSI DI CAMBIARLO SE CAMBIA NEL SETUP
Serial.println();
Serial.println();
if (sendStatus == 0) {
blinkIntervalMillis = fastBlinkMillis;
else {
void blinkLed() {
if (millis() - lastBlinkMillis >= blinkIntervalMillis) {
lastBlinkMillis += blinkIntervalMillis;
digitalWrite(ledPin, ! digitalRead(ledPin));
}and this is my rx code:
// https://github.com/HarringayMakerSpace/ESP-Now// This is the program that receives the data. (The Slave)
extern "C" {
#include <espnow.h>
#include <user_interface.h>
}// it seems that the mac address needs to be set before setup() is called
// and the inclusion of user_interface.h facilitates that
// presumably there is a hidden call to the function initVariant()/* Set a private Mac Address
http://serverfault.com/questions/40712/what-range-of-mac-addresses-can-i-safely-use-for-my-virtual-machines
Note: by setting a specific MAC you can replace this slave ESP8266 device with a new one
and the new slave will still pick up the data from controllers which use that MAC
uint8_t mac[] = {0x36, 0x33, 0x33, 0x33, 0x33, 0x33};//==============
void initVariant() {
WiFi.mode(WIFI_AP);
wifi_set_macaddr(SOFTAP_IF, &mac[0]);
// must match the controller struct
char text[32];
unsigned int time;
Serial.println("Starting EspnowSlave.ino");Serial.print("This node AP mac: "); Serial.println(WiFi.softAPmacAddress());
Serial.print("This node STA mac: "); Serial.println(WiFi.macAddress());if (esp_now_init() != 0) {
while (true) {};
}esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
esp_now_register_recv_cb(receiveCallBackFunction);
Serial.println("End of setup - waiting for messages");
void receiveCallBackFunction(uint8_t *senderMac, uint8_t *incomingData, uint8_t len) {
memcpy(&myData, incomingData, sizeof(myData));
int cm = myData.time / 29 / 2;
int inc = myData.time / 74 / 2;
Serial.print("NewMsg ");
Serial.print("MacAddr ");
for (byte n = 0; n < 6; n++) {
Serial.print (senderMac[n], HEX);
Serial.print(" MsgLen ");
Serial.print(len);
Serial.print(" Text ");
Serial.print(myData.text);
Serial.print(" Time ");
Serial.print(myData.time);
Serial.print(" CM = ");
Serial.print(cm);
Serial.print(" IN = ");
Serial.print(inc);
Serial.println();
every tips apreciated ...tanks a lot
