    M5Paper on macos Big Sur
    General
    5
    25
    56.8k
    • ajb2k3A
      ajb2k3
      I found an issue with the driver and had to select the kext file and now the driver works and usb serial is now working again!
      D 1 Reply Last reply Reply Quote 0
      • D
        darul75 @ajb2k3
        @ajb2k3 said in M5Paper on macos Big Sur:
        Hi @ajb2k3 what do you mean by selecting the ktext file, something like
        sudo kextload SiLabsUSBDriver.kext
        me it does not change anything, I am on OS Catalina
        • ajb2k3A
          ajb2k3 @darul75
          @darul75 said in M5Paper on macos Big Sur:
          Select? wow autocorrect!
          Nope, It should read delete.
          OSX has another driver that is conflicting with the slabs driver.
          J 1 Reply Last reply Reply Quote 0
          • D
            darul75
            I will try to do so deleting it
            • J
              joelsutz @ajb2k3
              @ajb2k3, what .kext did you delete? I can see that there is a conflicting driver but I can't figure out which one.
