    M5Burner: enable setting WiFi on "advanced" devices like Core2
    SOFTWARE
    4.5k
    • M
      mb
      I can use the M5Burner software to easily set the WiFi connection on the Atom.
      Why can't I use M5Burner to set the WiFi connection on my Core2?
      Sometimes after flashing the Core2 has lost the WiFi data and I find it cumbersome to use the integrated device setup.
      It would be great to use M5Burner to optionally set WiFi when burning UIFlow to Core2.
      • felmueF
        felmue
        Hello @mb
        you can, at least with M5Burner 2.2.4 on MacOSX I can.
        • start M5Burner
        • connect M5Core2 to your computer
        • select correct COM
        • click on Core2 Configuration
        • change settings
        • click Save
        Note: the 'Configuration' button is only available after downloading the UIFlow firmware and only works if M5Core2 is attached to the computer via USB.
        Thanks
        Felix
        Code examples
        • M
          mb
          Thanks @felmue, I just updated M5Burner to the latest version and now it works :-)
