    Core 2 and COMMU
    Core 2
    core2 commu arduino ide
    8
    24
    61.1k
    • C
      ChrisZang @felmue
      @felmue Yes, thanks that was it :-)
      So basically you compile & upload your sketch, you wait until the "...." appears, you press the button and then the upload works.
      Thanks again.
      C 1 Reply Last reply Reply Quote 0
      • felmueF
        felmue
        Hello @ChrisZang
        glad to hear you got it working.
        @TLS : thank you for figuring out the issue and letting us know.
        Thanks
        Felix
        Code examples
        • C
          ChrisZang @ChrisZang
          @chriszang and one more thing that I just learned:
          The GPIO for the CS Pin for the mcp2515 is 27 (not 12 as the documentation says).
          If you want to initialize the mcp2515 in the COMMU do this:
          MCP2515 CAN0(27); // (mcp2515 library)
          or
          MCP_CAN CAN0(27); // (mcp_can library)
          • C
            @chriszang and another update.
            So I am happily working on my CAN receiver sketch and just noticed that I forgot to press the button that grounds INT-output of the mc2515 but the upload still worked. Gave it another try (w/o pressing the button) and it's still working - weird.
            Then I swapped this COMMU module for my 2nd COMMU Module and here the upload doesn't work.
            My explanation is that the grounding of the mcp2515 INT-output basically created a short circuit in the transistor that controls this pin and eventually burned it out. Not a big problem for me as
            a) I am not using interrupts in my sketch
            b) I have a 2nd COMMU unit
            I just wanted to warn you guys that grounding the INT output has unintended consequences.
