    How to get Device infos from m5stack Devices
    General
    8
    23
    60.1k
    • M
      Medy @m5stack
      @m5stack I tried the
      import deviceCfg
      deviceCfg.get_board_name()
      it throws an error ....
        File "<stdin>", line 1, in <module>
        File "deviceCfg.py", line 270, in get_board_name
      TypeError: string indices must be integers, not str
      I tested all the other functions of deviceCfg and they all work ...
      but the one I asked you to add does not....
      hanks for implementing it .. but it doesnt work ;)
      • felmueF
        felmue
        Hello @Medy
        which M5Stack device did you try?
        I've just tested all of my M5Stack devices using UIFlow 1.8.7 and below code successfully (except M5StampPico which returns an incorrect name).
        import deviceCfg
        print(deviceCfg.get_board_name())
        Results for various M5Stack devices running UIFlow 1.8.7 firmware:
        M5Stack Gray : core
        M5Core2      : Core2
        M5StickC     : StickC
        M5StickCPlus : StickC-Plus
        M5CoreInk    : CoreInk
        M5Paper      : paper
        M5Atom       : Atom
        M5StampPico  : Atom
        Thanks
        Felix
        Code examples
        M 1 Reply Last reply Reply Quote 0
        • M
          Medy @felmue
          @felmue I tried the core gray
          guess I will try again and report back if it works.
          Ideally the the new m5 stamps will works as well with coming updates ?
