    Traceback on AtomMatrix when running example
    UIFlow
    6.0k
    • M
      mb
      Hi all,
      I am a newbie to M5Stack, just got my AtomMatrix and a few other goodies.
      I followed the instructions
      https://docs.m5stack.com/#/en/quick_start/atom/atom_quick_start_uiflow
      And ran the example code
      https://github.com/m5stack/M5-ProductExampleCodes/tree/master/Core/Atom/Atom Matrix
      Then I receive an error on the serial console and AtomMatrix shows a red X
        File "flow/m5cloud.py", line 82, in _exec_fun
        File "<string>", line 7, in <module>
        File "units/_rgb_multi.py", line 47, in set_screen
      IndexError: list index out of range
      UIFlow Web v1.4.5
      AtomMatrix v.1.6.5
      M5Burner 2.1.6
      Any ideas how to fix this?
      Thanks
      Mike
      • felmueF
        felmue
        Hello Mike
        I don't know if it helps, but I wouldn't mix UIFlow versions. Try selecting beta in UIFlow Web which should match the UIFlow firmware v1.6.5 on your M5AtomMatrix.
        Felix
        Code examples
        • M
          mb
          Thanks, I erased and re-flashed the AtomMatrix, now using v1.6.5 on device and web editor.
          A simple test program is working:
          Switch all LEDs red and green in loow
          But the official example from GitHub is failing with v1.6.5 (web + firmware).
          alt text
          • m5stackM
            m5stack
            thank you feedback, we will fix it as soon as possible.
            • felmueF
              felmue
              Hello Mike
              it looks like the AtomMatrix example has been replaced and works now. (And yes, the previous example was broken for me too.)
              Cheers
              Felix
              Code examples
              • M
                mb
                Thanks!
                • m5stackM
                  m5stack
                  it is an old version program compatible problem. now we updated a new example.
