    M5StickV Firmware_1017 Upgrade
    Official Updates
    7
    24
    94.5k
    • ajb2k3A
      ajb2k3 @Thrasher
      @thrasher said in M5StickV Firmware_1017 Upgrade:
      @ajb2k3 @Xeon
      I can help to translate into russian, with time.
      Whenever Ill have spare minute
      Thank you your support will be most appreciated
      • S
        staberas
        new bug:
        "pmu import axp192" interferes when i try to get gyro/accel data from the MPU6886
        m5stackM 1 Reply Last reply Reply Quote 0
        • m5stackM
          m5stack @staberas
          @staberas actually it not a bug . the K210 only three I2C interface, camera ,and some hardware dafuit use two interface . then PMU use one interface , if you want to use IMU , you shoud be Reasonable distribution I2C interface.
          • S
            staberas
            im not sure i understand, can u provide an example ?
            EDIT: it works now i have to comment out those two:
            #pmu = axp192()
            #pmu.enablePMICSleepMode(True)
            when added they the IMU locks up
