    UIFlow and usb connection
    UIFlow
    3.4k
    • P
      Powersoft
      I wont program my gray with UIFlow, but wont to have the interface between UIFlow and the gray over the USB.
      In the stand alone version I have download is that no problem. But when I use flow.m5stack.com it is not posible in my case. How can I change it in UIFlow so I can use the usb?
      Cheers,
      Jan
      MatiM 1 Reply Last reply Reply Quote 0
      • MatiM
        Mati @Powersoft
        @powersoft first grab latest m5burner and flash to latest uiflow or beta.
        Then power off stick
        Hold home
        And power on
        Now stick should wake up in boot menu.
        Inside there is a option and inside you can change it to pure usb mode.
        If you will have some problems i can digg out my stick to validate this steps.
