LCDVOL ?
Hi,
What does LCDVOL do? I assume change the LCD voltage? I've tried various values, 1 switches off the backlight but not sure what other values are supposed to do?I've searched but found nothing is there any documentation on this?
Thanks.
Hi Gadjet with the lcdvol block you can adjust the brightness of the lcd and also turn it off
lcdvol block?
@ajb2k3 yeah its only available for the stick on uiflow, in the hardwares section under AXP
Ah thanks
Thanks but is there any documentation on what values do what?
@gadjet not that I know off.
Please note that it is NOT LCDVOL that is a mislabel.
the function is actually LDO Voltage! -
lcdvol to control lcd voltage, must than 3V
