    How to save data to SD-card
    Bug Report
    7.0k
    • E
      Efried
      The UI flow is nice but you end nothing written to the file, it is only created - please provide an example. may be it needs some control characters
      thanks
      • m5stackM
        you could refer the demo block.
        替代文字
        • E
          Efried
          Would you mind adding some indication about control characters there, like "\r\n"
          Please recognize that you promised fast prototyping using the M5Stack but now it is clear that:
          • it is cumbersome, because the high level uiflow functions are not documented, and no working examples in micropython given to validate the high level functions
          • the combination of modules was not testet (ok a lot of variants)
          • the physical design has some flaws - the screen may brake when assembling, disassembling needs force - may be you may invent a receptacle with unlocking lever
          Do you have a standard before selling modules for quality control, and a test plan?
