    All IDE refuse to work with M5Stack now
    SOFTWARE
    5
    11
    17.8k
    • T
      Thrasher
      Hi!;
      First of all I wanted to say thanks for 1.6.1 FW which looks like a great progress and overall feel is much better! Great job;
      However
      None of IDE excepting online UIFlow works with M5Stack core now.
      VS Code won't connect.
      MU gives multiple error and can't access M5 storage;
      THonny connects and browses storage but can't save/run anything
      UIFlow offline version is outdated.
      Are there any plans to upgrade offline UIFlow at least? Online one isn't much convinient. MU/THonny looks just okay too.
      I can't build device fw with color blocks lol, want to type some;
      • K
        kylebuttress
        I have found the same with USB connected devices they are very difficult to connect with.
          I'm finding this aswel.
          @m5stack any idea what happened?
          • T
            Thrasher
            I'm not sure but there's probably major changes with 1.6 and later. Thats why UIFlow desktop not upgrading aswell
            • m5stackM
              which device are you use?
              • T
                Thrasher
                @m5stack M5Stack core gray with 1.6.1 UIFlow firmware
                • m5stackM
                  m5stack @Thrasher
                  @thrasher did you setup the device to USB mode?
                  we has test it. it working normal with vscode. maybe you could try to erase flash then upload the firmware again.
                  • lukasmaximusL
                    Make sure you have the stickC in USB mode, it's a little tricky, you need to hit the button on the right side really quickly on bootup. If you want to use in MU you need to change a config file, I mention it in this video https://youtu.be/15JrXn_9OWQ?t=80
                    • T
                      Thrasher
                      Yeah thanks @lukasmaximus and @m5stack
                      Ofcourse its on USB mode, I spent day trying different tricks with MU and THonny but I was using m5stack basic gray module, not stickC/Atom (I have them both so will try hopefully this weekend)
                      VS Code won't work still, it sends M5Stack into reboot and than can't access its inner memory, but it could be a driver issue, will keep trying
                      What's about offline uiflow ide?
                      • m5stackM
                        m5stack @Thrasher
                        @thrasher update your vscode and plugin and UIFlow desktop IDE to last version. then try again.
                        • T
                          Thrasher @m5stack
                          @m5stack
                          Hi, yes, with some updating and couple restarts VS Code now working with 1.6.1 UIFlow firmware
                          Thank you
