    Lesson 4.2.1. IO Ports. The brightness of the fire
    Scheduled Pinned Locked Moved Lessons and Guides
    3 Posts 2 Posters 14.8k Views 1 Watching
    • DimiD Offline
      Dimi
      Step 1. Go to the folder Arduino-ESP32-IDE and open the app arduino.exe (Fig. 1);
      alt text
      Figure 1. The archive with the Arduino IDE extracted to the folder
      Step 2. Select New on the File menu, (Fig. 1.1);
      alt text
      Figure 1.1. Create a new sketch
      Step 3. Select Include Library, M5Stack in the Sketch menu, (Fig. 1.2);
      alt text
      Figure 1.2. Connection library M5Stack
      alt text
      Figure 2. The view from the top. Bus connector input/output
      alt text
      Figure 2.1. The view from the back side. Stickers with captions ports
      Step 4. Add to the beginning of system functions void setup() function call M5.begin();
      Please note that the Arduino IDE does not support the standard functions for working with analog ports of the microcontroller ESP32.
      Add to the end system functions void loop() function call M5.update (); is required for correct operation of the device with built-in buttons (Fig. 2.2);
      alt text
      Figure 2.2 an example of the Correct preparation of the sketch
      Step 5. To work with PWM port (Fig. 2, 2.1) you can use the functions from list 1.
      List 1. Analog functions for ESP32
      • list itemledcSetup(uint8_t c, uint8_t f, uint8_t r); Sets the number of the channel c, frequency f (Hz) and resolution r (8 bits) for PWM
      • ledcAttachPin(uint8_t p, uint8_t c); Assigns the contact p to the channel c
      • ledcWrite(uint8_t C, uint8_t d); Sets the value of the filling signal d on channel c
      • ledcRead(uint8_t c); Gets the value of the PWM signal of the c channel
      Step 7. Write a brightness controller for led (Fig. 3);
      alt text
      Figure 3. Code brightness controller for LEDs
      Step 6. Prepare the led To 5 V and a resistor of 100 Ω (figure 4) and the cable, which is included in the kit (Fig. 4.1);
      alt text
      Figure 4. The led, resistor and M5Stack
      alt text
      Figure 4.1. Cable
      Step 7. Build the scheme according to figure 5;
      alt text
      Figure 5. Connect the led 21 to the contact
      Step 8. Click the Upload button (Fig. 6) to flash the device;
      alt text
      Figure 6. Download the firmware to the device
      Step 9. When the device firmware is completed, press the A button to increase the brightness B to decrease brightness of the led (Fig. 7, 7.1) :)
      alt text
      Figure 7. Increasing the brightness of the led with the button A
      alt text
      Figure 7.1. Decrease the brightness of the led with the button B
      • Z Offline
        zuobiao
        Thanks Dimi!
        Just a little remark: I can not see any figure of this lesson, Could you please check it?
        DimiD 1 Reply Last reply Reply Quote 0
        • DimiD Offline
          Dimi @zuobiao
          @zuobiao thank you! I'm working on a story, photos will be added soon
