    5V pin not working on a M5Stack core
    PRODUCTS
    11.2k
    • dasloloD
      daslolo
      What's the deal with the 5V pin, 0V on it, by design?
      • C
        Calin
        Is working just fine on my M5...
        • JJJ
          JJ @daslolo
          @daslolo
          Hi Daslolo,
          I presume you're talking about the 5V pin on the bottom module and not the Grove port ?
          If you want to pursue it, you could open up the bottom module and inspect that pin.
          Alternatively, you might still get 5V out of the Grove port.
          • dasloloD
            daslolo
            So @JimiT I tested the port, 5V flows through so the lower module has a problem.
            • dasloloD
              daslolo
              No response from the m5 team on twitter so I returned it through Amazon.
