M5Stack Delete App from App List UIFlow V1.5.4
How do I delete apps from the app list with the UIFlow firmware loaded?
Theres no direct way to do it from the menu, but you can do it with uiflow with this method
or in micropython:
import os os.remove('apps/nameofappyouwanttodelete.py')
@birdsong
m5burner has the erase - option where you can erase the device.
Than flash the firmware onto it. -
- Switch to you Python code
and at the bottom left corner select file manager to delete the apps that you dont want
This is a great answer.
It is not obvious that this functionality exists.
