    MtStickC accuweather.com mini weather station
    accuweatheruiflowrestweathermicropython
    7 Posts 3 Posters 18.3k Views 2 Watching
      robalstona
      Hello, I wanted to present a simple mini weather station program showing the current weather using the accuweather.com service. The program was made in UiFlow web ide 1.4.5 and tested on m5stickC firmware 1.4.2.
      source code and resource files:
      https://github.com/stonatm/m5stickc/tree/master/accuweather
      2_1593357350418_IMG_20200620_182603-1.png 1_1593357350406_IMG_20200620_182525-1.png 0_1593357350361_IMG_20200628_165756-1.png
        Ouu nice, can this be tied up with the env hat or yun?
          robalstona
          @ajb2k3 what connection do you mean ?. you mean hardware or program?
          • m5stackM Online
            m5stack @robalstona
            @robalstona
            him mean is these product:
            YUN:
            https://m5stack.com/collections/m5-hat/products/m5stickc-yun-hatsh20-bmp280-sk6812
            ENV-HAT:
            https://m5stack.com/collections/m5-hat/products/m5stickc-env-hat
              robalstona
              it seems to me that the author of the @ajb2k3 post wanted to display the data from these sensors / hats just like me
                ajb2k3 @robalstona
                @robalstona Hi, sorry I've been busy.
                I was wondering if you work could be combined with the hats and it all work or would adding the units cause something in your code to break.
                  robalstona
                  Yes, you must replace for example read temperature block with block which reads temperature from hat you use. Ewentually adds new block lcd.print for printing pressure and humidity with appropriate blocks reading data from these sensors But problems may be with icon and weather description, because the weather description and icon number corresponding to the current weather is downloaded from the accuweather.com website. some fun and testing with font type, coordinates and colors and it will work
