    UIFlow 1.5.4
    23 Posts 7 Posters 78.4k Views 1 Watching
    • m5stackM Online
      m5stack @ajb2k3
      @ajb2k3 yeah. ACSocket is a RS485 slave device. you need use RS485 communication to control it.
        @m5stack I'm trying to use the base26 rs485 adapter.
          Ouu the new burner looks nice!
          • OyczEO Offline
            OyczE
            Yep new Beta burner is great ! but got a bug with COM port refresh
            Check this out, erased or burned one Lite then another was connected with diff COM but when i try to burn / erase there is old come exist.
            text alternatywny
            • m5stackM Online
              m5stack @OyczE
              @mati thank you feedback. we will fix this bug as soon as possible
                sjako
                What's the latest stable (non beta) release of UIFlow, is that still 1.4.5? (When I download the version from https://m5stack.com/pages/download , I get 1.4.5)
                • m5stackM Online
                  m5stack @sjako
                  @sjako you could select 1.4.5/1.5.4 two UIFlow version in the navigation right side.
                    sjako @m5stack
                    @m5stack Thanks, I found it, it was a bit hidden =)
                    Maybe it should be a bit more clear 1.5.4 is a beta version? Maybe add a "b" after 1.5.4? Before I also tried the following option, but that's a completely different revision number
                    • lukasmaximusL Offline
                      lukasmaximus @cortado
                      @cortado They changed the method to get into USB mode, which is a little tricky, press the left hand button on your stick-c to reset and then quickly press the button on the right side to enter usb mode, the usb symbol will appear if you are successful
                      • m5stackM Online
                        m5stack @sjako
                        @sjako in the check update page.the version number is desktop IDE software version.
                          no hat and blocks for the rgb neoflash hat!
                            no blocks for neo butterfly launcher
                              StickC's not connecting to my wifi but my Core is connecting to my wifi!
                              • m5stackM Online
                                m5stack @ajb2k3
                                @ajb2k3 maybe you could check the ssid and password make sure they not problem. or erase the device flash then try again.
