    Button Error
    UIFlow
    7.0k
    • B
      birdsong
      What do you think is causing the error "'M5TextBox' object has no attribute 'wasReleased'" to display on the screen when I download the program to a M5stack?
      def buttonC_wasReleased():
        global bDecreaseSp, iMenu, bIncreaseSp, bTm250ms, thrd10ms, iBackLtTm20min, thrdDispStatBar, thrdDispPvSp, fPvHrs, bTm1s, thrdCtrlFan, thrd20ms, fPvTemp, bRunFan, bRunFanOld, bTm6min, thrd30ms, iTm250ms, bTm15min, iSpMode, iStatus, thrd40ms, fSpTemp, fSpRH, fSpMaxHrs, thrd50ms, thrd60ms, fPvRH, iTm1s, fSpHrs, iTm6min, iTm15min
        bDecreaseSp = True
        iBackLtTm20min = 4800
        pass
      btnC.wasReleased(buttonC_wasReleased)
      def buttonA_wasReleased():
        iMenu = (iMenu if isinstance(iMenu, Number) else 0) + 1
        pass
      btnA.wasReleased(buttonA_wasReleased)
      def buttonB_wasReleased():
        bIncreaseSp = True
        pass
      btnB.wasReleased(buttonB_wasReleased)
      • B
        birdsong
        @birdsong said in Button Error:
        Solution:
        I gave text a label btnA, when I changed it to labelA that bug was cleared.
        • m5stackM
          could you provide the whole program. it will very helpful for us to find the problem.
          • B
            birdsong @m5stack
            @m5stack Its ok thanks, problem solved. I gave the text label the name 'btnA' which is already a M5stack function, so renamingthe label cleared the problem.
