M5Stack after loading the program is still restarting.
 I have M5Stack.
 When I compile my program for Arduino 1.8.12, windows 7 32 bit and I do download with G0 = gnd with a speed of 115200, the program restarts in a circle.
 Other speeds don't work.
 below the log from the terminalrst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
 configsip: 0, SPIWP:0xee
 mode:DIO, clock div:1
 load:0x3fff0018,len:4
 load:0x3fff001c,len:1216
 ho 0 tail 12 room 4
 load:0x40078000,len:9720
 ho 0 tail 12 room 4
 load:0x40080400,len:6352
 entry 0x400806b8M5Stack initializing...<0><0><0><0><0><0><0><0><0>
 Booting device...
 Reading settings from eeprom.
 Settings not found. Initialization.
 Settings saved to eeprom.
 Init TFT display
 merged:6101FFF8000009285A3B0648030000B4179D763404080805000000
 merged:62B002E0000000FFB400330B0000000000000000
 Start BLE with PIN auth
 ets Jun 8 2016 00:22:57rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
 ho 0 tail 12 room 4
 ho 0 tail 12 room 4
 Booting device...
 Init TFT display
 merged:6101FFF8000009285A3B0648030000B4179D763404080805000000.........
 @spairo why you connect the G0 --> GND ?and which device are you use? M5Stack download program don't need G0-->GND. it differ other dev board
 I have m5Stack, a small black box with three silver keys and a TFT LCD display.
 I can't load anything into m5sstack if I don't give G0 then GND.
 I use 7 Pro x32 Win and I use Arduino 1.8.8 or 1.812.
 I don't know any other way to program m5Stack under Windows
 after download m5stack-ble black box is resrating in loop with register dump. Rebooting...
 ho 0 tail 12 room 4
 ho 0 tail 12 room 4
 entry 0x400806b8
 M5Stack initializing...OK
 Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
 Core 0 register dump:
 PC : 0x4010512d PS : 0x00050031 A0 : 0x4008565c A1 : 0x3ffbe360
 A2 : 0x00000000 A3 : 0x3ff48044 A4 : 0x800e04be A5 : 0x400916e8
 A6 : 0x00000000 A7 : 0x40085fb0 A8 : 0x00000000 A9 : 0x3ffbb700
 A10 : 0x00000000 A11 : 0x3ffbbd60 A12 : 0x800e04b3 A13 : 0x3ffbc010
 A14 : 0x00000000 A15 : 0x3ffbc03f SAR : 0x00000016 EXCCAUSE: 0x0000001c
 EXCVADDR: 0x00000000 LBEG : 0x00000000 LEND : 0x00000000 LCOUNT : 0x00000000
 Core 0 was running in ISR context:
 EPC1 : 0x4010512d EPC2 : 0x00000000 EPC3 : 0x00000000 EPC4 : 0x00000000Backtrace: 0x4010512d:0x3ffbe360 0x40085659:0x3ffbe380 0x40185037:0x3ffbc060 0x400e1a02:0x3ffbc080 0x40090745:0x3ffbc0a0 0x4008ef51:0x3ffbc0c0 Rebooting...
 ho 0 tail 12 room 4
 ho 0 tail 12 room 4
 entry 0x400806b8
 Problem has been solved
 The weak USB cable was to blame, after replacing the cable with the original Samsung, the problem did not return.
 Problem messages are:
 "BrownOut detector was triggered" and
 "The Guru Meditation" something like Blue screen of Death (BSOD)
