    UIFlow 1.5.2
    28 Posts 9 Posters 105.6k Views 2 Watching
      IR unit not supported
      • m5stackM Offline
        m5stack @Hugo
        @hugo could you provide whole program screenshot?
        • E Offline
          Efried
          It does no see the emoji library...
          • m5stackM Offline
            m5stack @Efried
            @efried thank you feedback , we will fIx this bug as soon as possible
              tialm
              Is it possible to know more about the ncir unit correction? What was wrong before? Asking because I am using a costume micropython version and want to know if I have to change something in my code.
              Thanks!
                jpilarski
                Very thankful for you all getting ble added to m5stack micropython. However I did notice a bug; it looks like
                blynk.init('fire', 'xxxxxxxxxxxxxxxxxxxxxx', blynk.BLE) needs to be added in prior to any of the other blynk related functions but it is often being added in after the other functions and this causes the board to become idle and while it doesn't throw any errors, it also doesn't successfully run the code as intended. I am sure this is a pretty easy fix. For now it looks like the workaround is to copy and paste the autogenerated python blynk related code into the correct order.
                • m5stackM Offline
                  m5stack @jpilarski
                  @jpilarski first add blynk init is necessary. if you use block program. you should put the blynk.init block to the setup. before use other blynk block.
                    jpilarski
                    The problem I am having looks to be whenever I add certain blocks, for example the loop block, it changes the position of the blynk.init() code and puts it several lines lower in the python code and thus out of order. Even when the blynk.init() was previously working, as soon as I add certain blocks, it puts the blynk.init() several lines lower in the code and this is preventing blynk from working and requires the user the manually cut and paste the blynk.init() line to put it in the correct position. Maybe I'm wrong about how I am using the the blynk blocks. It would be great to see a few screen shots showing how other users are implementing the blocks. thanks
                    m5stackM R 2 Replies Last reply Reply Quote 0
                    • m5stackM Offline
                      m5stack @jpilarski
                      @jpilarski could share you program ? I have test it. event i add a loop block. the blynk init seem still in the correct position. so if you could take a screenshot show me the program, it will very helpful for us to solve this problem.
                        jpilarski
                        @m5stack
                        Here is a quick example
                        This code doesn't ever connect to blynk. Here is the code it generates:
                        from m5stack import *
                        from m5ui import *
                        from uiflow import *
                        from ble import blynk
                        setScreenColor(0x222222)
                        label0 = M5TextBox(52, 10, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
                        label1 = M5TextBox(46, 49, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
                        circle0 = M5Circle(141, 122, 15, 0xFFFFFF, 0xFFFFFF)
                        val = None
                        message = None
                        blynk.init('fire', 'xxx', blynk.BLE)
                        while True:
                          circle0.setSize(val)
                          wait_ms(2)
                        @blynk.handle_event('connected')
                        def blynk_write():
                          global val, message
                          rgb.setColorAll(0xff0000)
                          pass
                        @blynk.handle_event('write v2')
                        def blynk_write(*args):
                          global val, message
                          val, message = args[0], args[1]
                          label0.setText(str(val))
                          label1.setText(str(message))
                          pass
                        Here is the manually adjusted code that connects with blynk.
                        from m5ui import *
                        val = None
                        message = None
                        def blynk_write():
                          global val, message
                          pass
                          global val, message
                          pass
                        while True:
                          wait_ms(2)
                        In the example above when the message variable is shown using label1.setText(str(message)) it shows the following ['255']. What is the most effective way in micropython to remove the [] and ' ' and convert message variable to an integer. I am using
                        which outputs this
                          global val, message
                          message = str(message.replace("'", '').replace(']', '').replace('[', ''))
                          circle0.setSize(int(message))
                          pass
                        but should generate this
                          global val, message
                          message = str(message).replace("'", '').replace(']', '').replace('[', '')
                          pass
                          robalstona @jpilarski
                          @jpilarski Some time ago I did custom blocks for blynk. They use rest api requests for communication, so they are not as advanced as those from uiflow. maybe these will work for you. I tested them on m5stickC and works.
                          https://github.com/stonatm/UiFlow-custom-blocks/blob/master/blynk/README.md
                            jpilarski
                            @robalstona @m5stack Thanks for that suggestion. I'll try the blocks you developed out on StickC. The new ble blynk blocks work it"s just they require a little tinkering with the micropython code to get them connected. At least that is my experience of using them. I am still very happy to see them included in the latest beta version of uiflow. Also I look forward to seeing a screen_shot showing all the blocks operating together in a single setup because I might be setting them up in a way that introduces the minor issues I've come across.
                            • m5stackM Offline
                              m5stack @jpilarski
                              @jpilarski ok, the problem is clear. thank you feedback, we will fix this bug ASAP.
                                jpilarski
                                @m5stack
                                Very cool. Thanks and it's really great to see bluetooth in micropython and uiflow. At one time you mentioned the micropython firmwares would be open source and made available on github, I know you have a uiflow micropython repo https://github.com/m5stack/UIFlow-Code but it doesn't always get updated with new releases, it would be great to see the repo get updated and have branches for each major release. I think so much great development can happen if the code is made available.
                                • m5stackM Offline
                                  m5stack @jpilarski
                                  @jpilarski You can talk about which lib your users want to open source.
                                    Thrasher @m5stack
                                    @m5stack
                                    Can we have document with something like:
                                    UIFlow lib
                                    --API
                                    --Methods
                                    --Method example / construction
                                    The way Arduino document its built-in libraries or similar to this?
                                    Thank you
                                    • m5stackM Offline
                                      m5stack @Thrasher
                                      @thrasher
                                      we had open source part UIFlow lib code. in this github :https://github.com/m5stack/UIFlow-Code
                                      Taking into account some lib data security issues, we will not open source all libs for the time being, so you can talk about which libs users want, we will consider if open source these lib.
                                        Thrasher @m5stack
                                        @m5stack
                                        I don't need source code.
                                        I'd like documentation on API usage
                                        E.g. LCD
                                        -Lcd.print(text, posx, posy, size) - prints a text string
                                        Etc.
                                        Im not looking for any source code
                                        Here's example from arduino:
                                        https://www.arduino.cc/en/reference/libraries
                                        And detailed info on functions:
                                        https://www.arduino.cc/en/Reference/SD
                                        No source code there but all functions detailed and explained how to use
                                        Because blockly, Im sorry, is just lame
                                          Sorry, I have been busy and suffering depression which resulted in my book getting neglected.
                                            jhfoo @ajb2k3
                                            @ajb2k3 Take care boss. Slow down and enjoy the earl grey.
                                            Also: don't.do.anything.stupid. :D
