    Bug? uiFlow 1.4.5 Stick C IMU ypr[] (getX and getY) values are weird.
    Bug Report
    10.7k
    • liemphL
      liemph
      I tried to get the roll, pitch, and yaw (ypr[]) of Stick-C IMU using uiFlow 1.4.5 (and 1.4.5.1) but the values seemed weird. X( ypr[1]) and Y (ypr[2]) are decreasing from time to time until the variables getting overflowed. I have checked my IMU using C++ (Ardunio IDE) and all were OK.
      liemphL 2 Replies Last reply Reply Quote 0
      • liemphL
        liemph @liemph
        • liemphL
          liemph @liemph
          @liemph
          from m5stack import *
          from m5ui import *
          from uiflow import *
          lcd.setRotation(1)
          import imu
          import hat
          setScreenColor(0x111111)
          hat_bugc0 = hat.get(hat.BUGC)
          imu0 = imu.IMU()
          label0 = M5TextBox(34, 10, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
          label1 = M5TextBox(35, 33, "Text", lcd.FONT_Default,0xFFFFFF, rotate=0)
          label2 = M5TextBox(10, 10, "X", lcd.FONT_Default,0xFFFFFF, rotate=0)
          label3 = M5TextBox(9, 34, "Y", lcd.FONT_Default,0xFFFFFF, rotate=0)
          raw_x = None
          raw_y = None
          raw_x = 0
          raw_y = 0
          while True:
            raw_x = imu0.ypr[1]
            raw_y = imu0.ypr[2]
            label0.setText(str(raw_x))
            label1.setText(str(raw_y))
            wait(1)
            wait_ms(2)
          • m5stackM
            m5stack @liemph
            @liemph thank you feedback . you could delete wait block to solve it. our engineer will fix it later .
            • I
              iPodLux
              Hi, the problem is still there. Removing the wait block kinda of fix it but reading are inconsistent. Any fix?
              • liemphL
                liemph @iPodLux
                @ipodlux For the time being, I stopped using uiFlow (or Python) for IMU related project. It is not reliable and it is slow. Use Arduino IDE, you will have a much faster code and reliable result.
