    Collision Detection between Objects w/ Joystick Hat Control (Micropython)
    PROJECTS
    3.4k
    • A
      AP1290
      I made a proof of concept for the M5Stick with Joystick hat. Using the joystick hat you can move a circle around the screen. Said circle has simple collision detection. Currently there is only one obstacle though. Adding more would be my next step.
      Also I included the ability to pause using button B. While paused you can even adjust the display brightness with the joystick.
      from m5stack import axp, btnA, btnB
      from m5ui import M5Rect, M5Circle, setScreenColor
      from uiflow import wait_ms
      import time
      import hat
      # configure size of deadzone on joystick input
      joyTolerance = 0.5
      # configure display
      intDisplayBrightness = 35
      setScreenColor(0x111111)
      axp.setLcdBrightness(intDisplayBrightness)
      # configure cursor position and size
      lstCursorCrd = [20, 5] # initial position
      cursorRad = 4
      circle0 = M5Circle(lstCursorCrd[0], lstCursorCrd[1], cursorRad, 0xFFFFFF, 0xFFFFFF)
      # rectangular obstruction and hit box around it
      obs = (29, 109, 20, 20)
      rectangle0 = M5Rect(obs[0], obs[1], obs[2], obs[3], 0xFF5500, 0xFF5500)
      rectLeadX = obs[0]
      rectLeadY = obs[1]
      rectEndX = obs[0] + obs[2]
      rectEndY = obs[1] + obs[3]
      # define joystick hat
      joy0 = hat.get(hat.JOYSTICK)
      #get center positions on joystick for calibration
      joyX = joy0.InvertX
      joyY = joy0.InvertY
      # store booleans of invalid motion
      boolXPlus = True
      boolXMinus = True
      boolYPlus = True
      boolYMinus = True
      # store timeouts to reduce collision flicker
      yTimeoutDur = None
      xTimeoutDur = None
      yTimedout = False
      xTimedout = False
      #store current state for play/pause
      play = True
      while True:
          while play is True:
              # move cursor hitbox
              circLeadY = round(lstCursorCrd[0]) - cursorRad - 2
              circLeadX = round(lstCursorCrd[1]) - cursorRad - 2
              circEndY = round(lstCursorCrd[0]) + cursorRad + 2
              circEndX = round(lstCursorCrd[1]) + cursorRad + 2
              if not ((circEndY > rectLeadY) and (circLeadY < rectEndY) and (circLeadX < rectEndX) and (circEndX > rectLeadX)):
                  # left
                  if lstCursorCrd[0] < 153 and (joy0.InvertY - joyY) > (0 + joyTolerance) and yTimedout is False:
                      lstCursorCrd[0] += abs((joy0.InvertY - joyY)/75)
                  # right
                  if lstCursorCrd[0] > 5 and (joy0.InvertY - joyY) < (0 - joyTolerance) and yTimedout is False:
                      lstCursorCrd[0] -= abs((joy0.InvertY - joyY)/75)
                  # down
                  if lstCursorCrd[1] > 4 and (joy0.InvertX - joyX) > (0 + joyTolerance) and xTimedout is False:
                      lstCursorCrd[1] -= abs((joy0.InvertX - joyX)/75)
                  # up
                  if lstCursorCrd[1] < 75 and (joy0.InvertX - joyX) < (0 - joyTolerance) and xTimedout is False:
                      lstCursorCrd[1] += abs((joy0.InvertX - joyX)/75)
              #collision detection code
              elif circEndY >= rectLeadY and circLeadY < rectLeadY:
                  # time out the cursor to prevent blink
                  yTimeoutDur = time.ticks_ms()
                  yTimedout = True
                  # move cusor back
                  lstCursorCrd[0] -= 1
              elif circLeadY <= rectEndY and circEndY > rectEndY:
                  yTimedout = True
                  # move cursor back
                  lstCursorCrd[0] += 1
              elif circEndX >= rectLeadX and circLeadX < rectLeadX:
                  xTimeoutDur = time.ticks_ms()
                  xTimedout = True
                  # move cursor back
                  lstCursorCrd[1] -= 1
              elif circLeadX <= rectEndX and circEndX > rectEndX:
                  xTimedout = True
                  # move cursor back
                  lstCursorCrd[1] += 1
              #render cursor in current position
              circle0.setPosition(y=round(lstCursorCrd[0]), x=round(lstCursorCrd[1]))
              # unpause cursor movement after set duration from collision
              if time.ticks_diff(time.ticks_ms(), yTimeoutDur) > 200:
                  yTimedout = False
              if time.ticks_diff(time.ticks_ms(), xTimeoutDur) > 200:
                  xTimedout = False
              # pause game with button
              if btnB.wasPressed():
                  play = False
              rectangle0.show()
          # adjust display brightness while paused
          if (joy0.InvertX - joyX) < (0 - joyTolerance) and intDisplayBrightness < 100:
              intDisplayBrightness += 5
              wait_ms(100)
          if (joy0.InvertX - joyX) > (0 + joyTolerance) and intDisplayBrightness > 20:
              intDisplayBrightness -= 5
              wait_ms(100)
          # resume game
              play = True
