    Problems with Vibrator Motor Unit in uiflow
    4 Posts 4 Posters 7.5k Views 2 Watching
    • drjakobD Offline
      drjakob
      The Vibrator Motor Unit is still missing as a unit in uiFlow 1.2.3 and 1.4.5. The official sample code (https://docs.m5stack.com/#/en/unit/vibrator ) won't work with M5Stack fire. The program always crashes when I try to digitalWritePin 26. Any ideas how to get vibrator motor working?
      • lukasmaximusL Offline
        you need to use the PWM blocks instead of digitalwrite, digital write is just for off and on but PWM can control the speed of the motor
        • world101W Offline
          world101
          Same thing for me on the Fan unit (which has the same N20 motor as the Vibrator motor unit). I tried PWM on Pin 26, but it just crashes after running the program.
          Even if I upload an empty flow with blank setup and loop functions, as soon as the M5Stack Fire boots, it tries to start the fan and crashes/reboots.
          I'm testing on Port B. If I switch to Port A, that port has power all the time and turns the motor on full blast and I'm not able to control it.
            Don't use it on port A use it only on port B.
            Confirmed, the motor doesn't work properly.
            I am sure that the unit only works as on or off as it only has an on/off transistor not a PWMable transistor.
