how many floors?
how many floors can have the m5stack?
Behold - the M5Stack Tower !
Hi Richard,
I don't think there is a hard limit on the number of "floors" or "stacks" that can be used with the M5Stack.
Behold - the M5Stack Tower below !! Using a total of 9 stacks, including Battery module , Lora module and 5x Proto modules.
Note there are some limitations on how the stacks can be used:
- I would suggest only using one battery module per stack.
- Some modules use the same GPIO - in this case only one module can be actively used at a time.
- The GPS and SIM modules use the same GPIO - the GPS continually sends data - so here it should not be used in the stack at the same time as GSM module.
@jimit thank you very much
@jimit 在 how many floors? ä¸è¯´ï¼š
"hack" one of them and move the rx/tx lines to different GPIO's then use serial1 to connect to that module.
Then you have 2 serial's and you can use both modules simultaneously.
When there is will, there is a way :D -
@calin the bottom stack should be the watch 😂
